Creating a polygon based on the limits of area geometries
yagami9
Hi everyone ,
Is there any way to create an area using the limits of area geometries in input ?
For exemple , if my geometries look like this  :
and if I use the BoundingBoxAccumulator transformer ,it only creates a box based on the limits of the input .
But I want the output to be like this :
  Any Insight is much appreciated !
Best answer by koulsoum
@yagami9 I have joined all in a zip file.
I used your screenshot of the polygons for the input called “test.png”.
joepk
Forum|alt.badge.img+20
  • March 4, 2024
yagami9
  • March 4, 2024
joepk wrote:
Thanks for the idea , It gives a better result than the BoundingBoxAccumulator  , but still very far from what I am looking for .
using the HullAccumulator
joepk
  • March 4, 2024
No worries, have you tried setting it to concave?
yagami9
  • March 4, 2024
joepk wrote:
Have you set it to concave?
Yes, I’ve tried to set it to concave , with different alpha values .but the result is still not good.
using concave , with alpha values : 0.75 , 1.75 , 4 ..
koulsoum
Forum|alt.badge.img+11
  • March 4, 2024
Hi @yagami9, I think you can :
  1. Assign an ID to each polygon.
  2. Transform the polygons into lines.
  3. Calculate the orientation of each line.
  4. Group lines with the same orientation.
  5. Extend the lines.
  6. Do a spatial join, grouping by elements with the same orientation but not from the same polygon.
  7. Remove unnecessary elements (outside the polygons).
  8. Select overlapping lines and combine them.
  9. Recreate polygons from the new and original lines.
  10. Merge all polygons into one and remove any holes if present.
I have tested it, I am joining the screenshot of the workflow and the result I have obtained.
yagami9
  • March 4, 2024
@koulsoum Thanks for the response ! The screenshots of your workflow aren’t visible.
Could you please re-send them .
koulsoum
  • March 4, 2024
yagami9
  • March 4, 2024
@koulsoum Thanks a lot for your time and help !
Could you please share the .fmw file of that workflow ? and the input if that is possible .
I tried to recreate it , but only a few features pass the Tester (_related_suppliers>0 ) , the rest have the value _related_suppliers= 0 .  .
koulsoum
  • March 5, 2024
yagami9
  • March 5, 2024
@koulsoum Thanks a lot !!! It works
