Creating a perpendicular line through a point and clipping it within a Polygon using FME 2019.2.3
ivanvdn94
Hey everyone. I have 3 road datasets I am working with. One point, one line and one polygon. I need to join these three datasets. The point data is set so that each point is about 100m from one another. I can manage to merge all the data but now I need to create a perpendicular line through my points to create segments of my road data.
This is how I need to divide my roadsThis is just the logic i used to merge and filter my data
danminneyatsaf
Forum|alt.badge.img+13
Hey @ivanvdn94​ take a look at this other community post which has some explanation on how to do the same: https://community.safe.com/s/question/0D54Q000080hWRhSAM/creating-a-line-between-two-nearest-points
You'll likely want to find the nearest point to each point using the NeighborFinder and then use a VertexCreator to create the line feature from the two points.
havmoejbv
Forum|alt.badge.img+15
  • October 10, 2023
I guess there are multiple ways of solving this, here's one suggestion:
1 - If you want to segment the data at fixed intervals along the line you can divide the line with a Chopper (Mode: By Length).
2 - If you create a topology of this with TopologyBuilder you get a direction angle of the line in each node.
3 - Use the Offsetter to create points at a suitable distance from the line at a right angle.
4 - Use LineBuilder (grouped by node ID) to create the perpendicular lines
