Create groundlevel polygon (including height) from las file
  • Oct 23, 2018 9:48 AM UTC
  • 28 views
stefanh
Forum|alt.badge.img+8
I need to create a groundlevel polygon from a las file, including the height. No classification is added to the pointcloud.
It doesn't need to be precise; otherwise there would be generate to many polygons. A generalisation would be perfect.
For example I get a polygon where the height is between 17 and 17.50 meter; and another polygon where the height is between 17.50 and 18 meter
I tried serveral thing with surfacemodeller, surfacebuilder, creating buffers around the points. But I can't get my hands around this issue.
Hope someone as experience with such an analysis
nathanatsafe
Forum|alt.badge.img+9
Hi @stefanh,
Have you tried the PointCloudFilter? You can chose to filter by the z component, and create an expression where it is > 17.50 and < 18 meters. Following this you could use a HullReplacer to create a very generalized polygon. Alternatively, using a PointCloudCoercer before the HullReplacer would allow you to create more precise areas out of your points.
Hope this helps,
Nathan
