Create a point in the middle of an arc
  • Sep 16, 2014 1:19 PM UTC
  • 7 replies
  • 100 views
mica
Participant
Hello,
I import arcs from a dwg file and I need to create a point in the middle of  these arcs.
How I can do?
Thanks
Mica
  • Sep 16, 2014 2:26 PM UTC
Hi Mica,
You can use the Snipper to create the middle point of a curve including arc.
Firstly, calculate the half length of the arc. LengthCalculator and ExpressionEvaluator can be used, for example. And then use the Snipper with these settings:
Snipping Mode: Distance (Value)
Starting Location: <the half length>
Ending Location: <the half length>
Hope this helps.
Takashi
mica
Participant
  • Participant
  • Sep 16, 2014 2:45 PM UTC
Thank you Takashi!
It's exactly what I need.
gio
Forum|alt.badge.img+15
  • Sep 16, 2014 2:47 PM UTC
The easiest way omi.
First arcs must have some ID
1) use a boundingboxreplacer on the arcs. Set it to orientedboundingbox.
Replace with its centerpoint. Extract coordinates.
2)
Paralell to this: stroke the arc and extract 1st and last coordinate.
3) Merge 1 and 2 by ID.
Use creator to midpoint of points found at 2)
Vertexcreate, set to replace.
Vertexcreate cordinates from step1) Set to add.
This should give u a line troug center of outerpoints of arc.
Extende by at least half of shortlength of boundingbox (this is a attribute of the boundingboxreplacer).
Intersect this line with the boundingbox.
You should end up with the midpoint of arc.
  • Sep 16, 2014 3:01 PM UTC
Oh, I've overlooked "Distance (Percentage)" mode. You don't need to calculate the lentgh.
Snipping Mode: Distance (Percentage)
Starting Location: 50
Ending Location: 50
gio
  • Sep 16, 2014 3:10 PM UTC
To actualy get the vertex using snipping you would have to :
gio
  • Sep 16, 2014 3:12 PM UTC
gio
  • Sep 16, 2014 3:17 PM UTC
Yes i forgot, it outputs the point if start and end are same...erhmm.
