Create a PDF map from an existing ArcGIS Pro Layout using FME Desktop or Server.
  • Nov 8, 2021 2:56 AM UTC
  • 726 views
Can anyone explain what I need to do in FME to connect to an ArcGIS Pro Layout to create the PDF Map of the Layout. Do I need the FME Data Interop Extension in ArcGIS Pro to do this via Python? Does anyone have examples of this code?
hkingsbury
Forum|alt.badge.img+73
  • Nov 8, 2021 7:25 PM UTC
You'll need to embed some ArcPy Python in your workbench. Here is an example of how to use ArcPy in FME:
https://community.safe.com/s/article/using-arcpy-for-fme-feature-processing
And example of the script to export a layout to pdf is here:
https://gis.stackexchange.com/questions/316471/exporting-to-pdf-using-arcpy-of-arcgis-pro
and there is some more documentation here:
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/pdf-export.htm
  • Nov 8, 2021 10:46 PM UTC
Thanks for the quick reply @hkingsbury​ I will let you know how I go.
