Count Increased Based on a Condition Being Met
tiztrain
Forum|alt.badge.img+5
I am wanting to create a count that increases if a condition has been met. So as an example, if TIME is greater than 100 then the COUNT increases, otherwise it stays the same:
TIME - COUNT
20 - 1
70 - 1
130 - 2
220 - 3
40 - 3
80 - 3
370 - 4
Been stuck trying to figure this out for a while. With Python this would be easier with the use of variables but I am struggling with FME on this one.
I see the Count transformer has 'Group By' capability but I don't think that helps me for this situation.
Best answer by nielsgerrits
tiztrain wrote:
So I had already done this with the Attribute Manager but the part I am struggling with is the conditional statement.
I was using the Count() function to count whenever the condition is met and that works fine for when the count increases but is there a way to display the count without adding another count. If that makes sense?
How I do this:
  • AttributeCreator to create attribute _count with no value.
  • Second AttributeCreator with one prior feature.
    • If previous value has no value, then _count = 1
    • Else if value > 100, _count = previous _count + 1
    • Else _count = previous _count
Not sure if this is the official way, but it works.
nielsgerrits
Forum|alt.badge.img+58
If you want to do this in the excel way, look at previous rows etc, you can do this using the AttributeCreator, Advanced: Attribute Value Handling, Enable Adjacent Feature Attributes. Then use conditional values.
tiztrain
  • January 15, 2024
nielsgerrits
  • January 15, 2024
How I do this:
tiztrain
  • January 16, 2024
Oh this is interesting. I was stuck on how to use the existing attribute in my Conditional Visibility but did not realise that you just need to create the value in a AttributeCreator and then reuse it in the second one. Man makes calculating this so much easier. Works perfectly.
Appreciate it.
nielsgerrits
Cheers :)
