Convert Solid to 2d shape
  • Feb 24, 2022 2:32 AM UTC
  • 71 views
I have a smart solid model of a building made in Bentley. I would like to drop solid and take the top view drawing out. Solid dissolver is not working. Any help is greatly appreciated
  • Feb 24, 2022 5:33 AM UTC
Hi @pkrishnamohan​ , have you tried using the SurfaceFootPrinter transformer?
caracadrian
Forum|alt.badge.img+23
  • Feb 24, 2022 5:41 AM UTC
Try to use Deaggregator to get individual solids, followed by GeometryCoercer set to fme_composite_surface and Deaggregator again to split into individual surfaces.
Now you can begin to test which surface is on top (determine which surfaces overlap each other, get z min and max for each one) and keep only the top one.
For more in depth ideas please provide a sample of your smart solid.
