Convert Lat/long coordinates to UTM
  • October 11, 2018
  • 206 views
mr_fme
Forum|alt.badge.img+9
How do I convert geographic coordinates to UTM in FME. I have not found anything simple, I do not believe that the FME does not do it simply.
thank you
Best answer by david_r
If the lat/long coordinates are given in degrees/minutes/seconds, you may want to look at the DecimalDegreesCalculator as well, it will let you convert those three values to decimal degrees.
  • October 11, 2018
Hi @mr_fme, have a look at the AttributeReprojector or the CsmapAttributeReprojector.
  • October 12, 2018
