Convert 3D models to ECEF?
Do you have any Python or TCL code or any example job for converting from a WGS84 3D model to a 3D model with ECEF coordinates?
https://en.wikipedia.org/wiki/ECEF
Best answer by davidcollins
Thanks @takashi. Has worked brilliantly! :)
I need to convert lat,long,height coordinates to ECEF coordinates in the 'vertex pool' of a 3D feature, without modifying the 'parts' of the 3D feature. (Visualizer terminology)
I have a Python function that will perform the coordinate conversion.
In a PythonCaller I am able to print out all the vertices that I need to modify, but while reading the API documentation, I have not been able to work out how to modify the list of vertices in the 'vertex pool'.
PythonCaller code for printing the vertices' values ..
geom = feature.getGeometry()
vtcs = geom.numVertices()    # from FMEMesh class
log.logMessageString(str(vtcs))
for i in range(0, vtcs):    log.logMessageString(str(geom.getVertexAt(i)))    # from FMEMesh class
Hi @davidcollins, this is a skeleton for the PythonCaller. The strategy is to replace the current mesh with a new mesh which consists of the converted vertex pool and the same parts structure. Please define the "convert" function appropriately to convert coordinates (x, y, z) from WGS84 to ECEF.
import fmeobjects
def processFeature(feature):
    def convert((x, y, z)):
        # TODO: convert coordinates from WGS84 to ECEF
        return (x, y, z)
    # Get the current mesh geometry.
    curMesh = feature.getGeometry()
    # Create a new mesh geometry,
    # append converted vertex pool to the new mesh,
    # copy every part from the current mesh to the new mesh,
    # set the new mesh to the input feature.
    newMesh = fmeobjects.FMEMesh()
    newMesh.appendVertices([convert(v) for v in curMesh.getVertices()])
    for part in curMesh:
        newMesh.addMeshPart(0, part.getVertexIndices(), None, None)
    feature.setGeometry(newMesh)
import fmeobjects
        return (x, y, z)
For anyone interested in this article ..
I am using the following WGS84 - ECEF conversion, but I think I might need to do some work on it.  http://adore-doris.googlecode.com/svn/trunk/lib/python/basic/projections/ecef.py
For the conversion, I needed scipy, so I installed 64-bit WinPython 2.7 (including the SDK option) and set FME to use this as a 'Custom Python Interpretter'.
To get rid of an 'ImportError: No module named site' error, I needed to ..
  • Run
    SystemPropertiesAdvanced.exe
     and set system variables ..
    • PYTHONHOME=C:\WinPython27\python-2.7.10.amd64
    • PYTHONPATH=C:\WinPython27\python-2.7.10.amd64\Lib
    • add %PYTHONPATH% to end of PATH system variable
import fmeobjects
        return (x, y, z)
I attach development versions of the files.
obj2-collada-neogb.fmw - FME job
neo-gb-5km-devonian.txt (rename to .obj to use - this is a wavefront obj file)
ecef.py - WGS84 to ECEF conversion code
These all need to be placed in c:\3D
