Connecting a Transformer to Multiple Connections
  • July 2, 2013
  • 7 views
I'm am working on an FME job with about 65 different input and output features. I'd like to know if there is a method to insert a TimeStamper transformer between each input and ouput connection without having to do it manually each time. Thanks in advance!
  • July 3, 2013
I don't think there is a way to insert transformers without some manual operations. Using the Feature Type Connections functionality, you might be able to save a little labor.
Takashi
