Comparing dates in FME
Hi there,
I am trying to filter (using tester) the data on the basis of dates (i.e. month and Year). I have converted the dates into desired format using DateTimeFormat function. When I run the tester, it does not give the right result. In the passed data tab I could see the dates row that should have been in the failed data tab. I have attached the screen shot of my test parameter. Could anyone guide where am I making the mistake?
Best answer by takashi
Hi @muhammad_yasir, If you convert the datetime format into Standard FME Date/Time Format, you can compare the datetime values by setting the Comparison Mode parameter in the Tester to "Date/Time".
If you can't see the logic of the tester here is the value
@DateTimeFormat(@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d),%m %Y) >= @DateTimeFormat(@DateTimeAdd(@DateTimeNow(),-P8M),%m %Y)
AND @DateTimeFormat(@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d),%m %Y) <= @DateTimeFormat(@DateTimeAdd(@DateTimeNow(),P3M),%m %Y)
  • December 18, 2019
@takashi I just tried that. But ended with the same result.
Hi @takashi, I just noticed that I am getting following warning message when I run the tester.
Tester (TestFactory): TestFactory: Unable to do a date/time comparison of 'yyyymm' and 'yyyymm'. Comparing as strings instead.
  • December 18, 2019
My intention was to set these expressions. Both @DateTimeParse function and @DateTimeAdd function return a datetime value formatted in Standard FME Date/Time Format.
Doesn't this work for you?
@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d) >= @DateTimeAdd(@DateTimeNow(),-P8M)
AND
@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d) <= @DateTimeAdd(@DateTimeNow(),P3M)
Comparison Mode: Date/Time
  • December 18, 2019
If you need to compare only year and month part, this expression would be available.
@DateTimeFormat(@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d),%Y%m) >= @DateTimeFormat(@DateTimeAdd(@DateTimeNow(),-P8M),%Y%m)
AND
@DateTimeFormat(@DateTimeParse(@Value(INCIDENT_TIME), %Y-%m-%d),%Y%m) <= @DateTimeFormat(@DateTimeAdd(@DateTimeNow(),P3M),%Y%m)
Awesome. It worked. Thanks for clarification. Last thing, Can I add multiple but different conditions in single tester? If yes, Can you explain how?
  • December 18, 2019
Consider using TestFilter instead.
Is it the same as Tester ?
AND
This condition does not work. However, above mentioned condition does work
  • December 18, 2019
Similar to the Tester, but you can add any number of output ports for the number of your desired conditions. See the help on the TestFilter transformer to learn more.
