I have a DWG that I am trying to create a polygon from to represent the extents of the data.
The polyline data doesn't seem to be able to be coerced to form a polygon and I am unsure why.
I have tried to aggregate the polylines into a single feature, but no luck.
Best answer by nielsgerrits
Coercing a polyline to a polygon only works when the polyline is in one piece and the endpoints are snapped to each other.
What you probably need is an AreaBuilder. You probably need to clean up a little using the Snapper and the Intersector.
Awesome. Exactly what I needed. Most appreciated.
19 votes
18 votes
16 votes
14 votes
13 votes
12 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
