Clipper transformer with multiple Rings and multiple Raster Files as Candidates
  • Sep 8, 2023 10:05 AM UTC
  • 78 views
maisels
Forum|alt.badge.img+3
Hello, I have the following problem. I have a file with a lot of rings, which all have a unique ID. On the other side I have a lot of raster files which also have this ID as file name. Now I want to crop each one of the raster files to the corresponding outline with the same ID. These cropped individual raster files are then to be saved individually. How can I tell the Clipper Transformer to "blend" the ID of the ring with the ID of the raster file ? Maybe someone can give me a hint.
Many thanks and best regards
Maisels
tomfriedl
Forum|alt.badge.img+14
  • Sep 8, 2023 10:20 AM UTC
Look at the param "Group Processing" by the Clipper, Group By = ID
maisels
  • Sep 8, 2023 10:54 AM UTC
Perfect, that was the right hint, now it works.
I also had to assign the id as attribute to the Rasterfiles.
Thanks a lot !
