Charvar to Date format
imageI have CSV file in the character format with a value as shown here. I would like to change it into Date format so I will be able to date calculation later. I tried to use Dateformater. it did not work. is there any other transformer that I can leverage to accomplish this?
Best answer by ebygomm
kris_ab wrote:
I just wonder should I have Date field before using dateformatter transformer? I want to change varchar to Date.
You don't need anything but the DateTimeConverter, e.g. using the csv you posted
Forum|alt.badge.img+58
Which parameters did you use in the DateFormatter?
  • May 6, 2023
Hello Redgeographics Thank you for your time.
Since my existing date is month day and year in string format, I used default to let FME or ISO to find the input parameter. Also I did not find m%d%y% format in the dropdown list. the output format I used default and %Y%m%d. The transfer ran successfully but the outcome filed was still sting in Sep 2, 2022. No changed literally. A little doubt about the datetime attribute, there was cor_date field and also @value(cor_date). I tried both. not sure of the difference between them.
imageAlternatively, I created the separate Date field and copy all information from occ_date to date field. The date field was no value.
The thing with the DateTimeConverter is that if the format you have (or want) is not in the dropdown list you can add the format string yourself. So "Sep 2, 2022" is %b %e, %Y (3-letter month 1- or 2-digit day, 4-digit year
  • May 8, 2023
Hi, I changed input and output format as %b %e, %Y, but the workbench ran successfully. The field also changed to Date format, but the values were null. All dates values were not carried over.
Forum|alt.badge.img+43
  • May 8, 2023
The input format in your screenshot and your sample csv file are different, can you confirm which is correct?
So for your screenshot it would be
%b %e, %Y
But for your csv example file the input format would be
%e-%b-%y2099
  • May 8, 2023
%b %e, %Y
%e-%b-%y2099
  • May 9, 2023
  • May 9, 2023
thank you very much
  • May 9, 2023
Hello Ebygomm, the resultant table is as follows: the date field still looks. varchar. I was expecting this field Date, wasn't I?
  • May 10, 2023
To write out as a date you will need to change attribute definition to manual and change the type to date
