Can you round to the nearest even number using AttributeRounder or CoordinateRounder?
Hi, I would like to round a elevation value to the nearest even number. Is there a way to do this, perhaps using AttributeRounder or CoordinateRounder?
I am using FME Desktop 2016.
Thanks
Best answer by redgeographics
If you use the expression @round(@Value(attr)/2)*2 in an AttributeManager or AttributeCreator it should do the trick.
  • July 11, 2017
Does the elevation value have decimal places?
  • July 11, 2017
Hi Takashi, Yes it does have decimal places. Thanks
Forum|alt.badge.img+58
  • July 11, 2017
  • July 11, 2017
Oops, my question was stupid. I wanted to ask whether the resulting elevation should have decimal places, but "even" number is usually an integer. @redgeographics suggested the way to go.
  • July 11, 2017
Thanks guys, @redgeographicsanswer worked !
