Can you round to the nearest even number using AttributeRounder or CoordinateRounder?
Hi, I would like to round a elevation value to the nearest even number. Is there a way to do this, perhaps using AttributeRounder or CoordinateRounder?
I am using FME Desktop 2016.
Thanks
Best answer by redgeographics
If you use the expression @round(@Value(attr)/2)*2 in an AttributeManager or AttributeCreator it should do the trick.
Does the elevation value have decimal places?
Hi Takashi, Yes it does have decimal places. Thanks
Forum|alt.badge.img+63
Oops, my question was stupid. I wanted to ask whether the resulting elevation should have decimal places, but "even" number is usually an integer. @redgeographics suggested the way to go.
Thanks guys, @redgeographicsanswer worked !
