Calculating a 'next scheduled date' based on a 'last scheduled date' plus a frequency (FME 2015)
  • Feb 27, 2019 1:19 PM UTC
  • 60 views
Hello,
I'm trying to work out a way to calculate a forecasted date from an existing recorded date + a numeric frequency. I understand there is a transformer in a more recent version of FME, however this isn't an option for me.
Is there any way I can convert the date into a number, add the frequency, and then convert the number back to a date?
Thanks in advance!
Forum|alt.badge.img+54
  • Feb 27, 2019 1:35 PM UTC
I don't have 2015 to check what's possible there, but I think you should be able to convert the date to seconds(%s) in a dateformatter, add the additional amount needed in seconds then convert back to a date
Forum|alt.badge.img+63
I'd like to add that if you have the opportunity to upgrade to FME 2018 the DateTimeCalculator will prove very good at this task.
  • Feb 27, 2019 2:49 PM UTC
That's solved it. Many thanks!
