Calculate UTC time in FME 2014
  • Jan 22, 2020 9:08 AM UTC
  • 14 replies
  • 144 views
fikusas
Forum|alt.badge.img+5
How to get UTC time in FME 2014? TimeStamper gives local time >>
When in DateTimeCalculator I'm subtracting hours from local time to get UTC time, but this won't work after Daylight Saving Time begins.
Best answer by ebygomm
This worked for some time, but stopped recently. Maybe it is possible convert local time (with Daylight savings adjusted) to UTC via Python script?
Not sure whether this will work in 2014, I think it should. But you can use an InlineQuerier to return UTC
e.g.
select datetime('now') as utc
Worth a try
Forum|alt.badge.img+63
Not an answer to your question I'm afraid, but if you have the chance to update to FME 2019 that would be highly recommended, the date/time functionality is vastly improved in recent versions.
fikusas
  • Jan 22, 2020 9:23 AM UTC
Yeah, I know it's easy to pull it in 2019. But I need to get UTC in 2014...
  • Jan 22, 2020 11:17 AM UTC
I'm not sure this works in your timezone, but Tcl has a function to convert a local time to other timezone including UTC. Try setting this expression to the Tcl Expression parameter in the TclCaller. Assuming the input "timeposition" (local time in your machine) is formatted with the ISO standard date/time format (%Y-%m-%dT%H:%M:%S).
clock format [clock scan [FME_GetAttribute timeposition] -format %Y-%m-%dT%H:%M:%S] -format %Y-%m-%dT%H:%M:%S -timezone :UTC
See here to learn more about the clock command in Tcl: https://www.tcl.tk/man/tcl8.5/TclCmd/clock.htm
And available timezone names are here:  https://wiki.tcl-lang.org/page/timezone
Again, I don't know if Tcl supports your timezone with daylight saving time. Please make enough test.
robotix
Forum|alt.badge.img+10
  • Jan 22, 2020 2:52 PM UTC
I have a solution but it requires a couple more steps in your process. Not super elegant but it works.
We occasionally use a date reference table in a database to determine daylight savings, Then reference the table to determine how to calculate time. Subtract or add so many hours depending upon start and end of daylight savings. The number of hours to add or subtract is dependent upon your time zone.
You could always create a spreadsheet with something similar. Compare to dates in the spreadsheet and in your transformation(s) say IF datetimenow()>dst_start and datetimenow()<dst_end then +- hours.
We reference the year then determine. Here is a snippet of our table.
Best wishes.
fikusas
  • Sep 21, 2020 5:29 AM UTC
  • Sep 21, 2020 8:10 AM UTC
@fikusas​ , are you still using FME 2014?
fikusas
  • Sep 21, 2020 8:12 AM UTC
Yeah, still using FME 2014. There's no doubt how to do it in newer versions.
Forum|alt.badge.img+54
  • Sep 21, 2020 8:36 AM UTC
e.g.
Worth a try
fikusas
  • Sep 21, 2020 8:59 AM UTC
It works, but returns no geometry. I'm reading some points and need to assign UTC time to those points.
  • Sep 21, 2020 9:06 AM UTC
I'm not sure with your workflow whether you can generate the utc time with the inline querier then merge onto your points, alternatively you can extract your point geometry to an attribute and then rebuild it again after the inlinequerier.
fikusas
  • Sep 21, 2020 9:20 AM UTC
How do I select attributes and generate UTC time in the same querry? This doesn't work:
SELECT "beginposition","endposition","timeposition","datetime('now') as utc"
FROM Output
  • Sep 21, 2020 9:25 AM UTC
SELECT "beginposition","endposition","timeposition",datetime('now') as utc
FROM Output
Remove the double quotes from the datetime('now') part
fikusas
  • Sep 21, 2020 9:29 AM UTC
It works! Thank you.
  • Sep 21, 2020 11:16 AM UTC
If "beginposition", "endposition" and "timeposition" are attributes contained by input features, try this query.
SELECT *, datetime('now') as utc
FROM Output
