CAD TO GIS TRANSFORMATION
  • April 24, 2013
  • 5 replies
  • 176 views
Hi all,
anybody know how to show coordinate information on point feature in CAD?i have point details at CAD drawing, so i have to transfer point's coordinate to GIS?anybody can tell me what certain transformer in FME that i should use?thanks..
davideagle
Forum|alt.badge.img+21
  • April 24, 2013
Hi - unless you are working AutoCAD Map 3D it's unlikely that the CAD file has a coordinate system defined on it. In this case assuming the coordinates in the file are in the correct place then when you convert your data from CAD (perhaps DXF or DWG) then place a CoordinateSystemSetter transformer inline and set the parameter to the correct coordinate system. This simply tags each feature with the required coordinate system so that when you open your GIS file all the points should be in the correct coordinate space.
Hope that helps.
  • April 24, 2013
thanks Mr Dave..but can you tell me how to know the coordinate system used in survey plan from other company?actually, i have no idea to identify the coordinate system attach to the plan...
  • April 24, 2013
I think you have two options
  1. Ask them (probably the best option).
  2. Make an educated guess based on the x,y coordinate values. Try to superpose the data visually over known terrain to verify your findings, e.g. by overlaying your data over a map service such as a cadastral WMS or Google Earth to check that it matches.
David
davideagle
  • April 24, 2013
Yep - unfortunately you'll have little choice but to speak to the person who produced the data. CAD files typically do not retain any hints as to 'where' the data is. That detail is largely in the head of the CAD operator. If you can't get hold of that person immediately then assuming you know the name of the town or place on the map you could do a web search on an online map to find the location, then based on the country make an educated guess. I find this website useful as it allows you to do a keyword search too, so add a country name and hit 'Convert' and see which coordinate systems are suggested:
http://prj2epsg.org/
  • April 29, 2013
Hi Dave, thanks for your suggestion.but please let me know where to paste the wkt representation after we insert the city name?
