AutoCAD text point location/justification?
  • Jan 9, 2021 2:47 PM UTC
  • 428 views
townest
Forum|alt.badge.img+4
I've noticed that FME converts AutoCAD text into a point at the bottom left justification of the text even though my CAD drawing has the text justified middle center. Is there any way to adjust where FME reads the text into a point? Thank you.
Tyler
FME(R) 2020.2.1.0 (20201130 - Build 20806 - WIN64)
Best answer by caracadrian
Filter the text featuretypes via GeometryFilter and use an AttributeExposer to get the insertion point of the acadfeature: autocad_alignment_x, y, and z.
autocad_alignmentThen just use a VertexCreator (+LabelPointReplacer + Rotator) to replace everything to the correct coordinates, size and rotation.
autocad_vs_inspector_text
caracadrian
Forum|alt.badge.img+23
  • Jan 10, 2021 2:03 PM UTC
townest
  • Jan 10, 2021 3:23 PM UTC
Thank you!
