Adding titles in PDFPageFormatter
ako_tde
Hello FME enthusiasts,
I am slowly getting better within FME – but now and then I simply get stuck.
In my example, I load a simple .xlsx File with a borehole identifier (BID) and a complementing link to its online available drilling profile (URL).
The goal is to extract the profile for each BID via ImageFetcher and to write it into a single .pdf File via the fanout option.
Works great so far, but I just cannot figure out how to provide the BID as additional information (here: headline directly in each .pdf) via the PDFPageFormatter. Whatever I do, only the fetched raster image is written as .pdf File.
This is more a general question, as more information could be added to the .pdf File (e. g. date and time of image extraction).
Please see my attached FME template file.
I am quite sure the solution is simple, but I need some help/hints.
Thank you in advance!
Kind Regards
Alexander
Best answer by redgeographics
You'll need to create a feature with geometry in order for the PDFPageFormatter to pick it up. So the features that go in to the Query port should first go through a VertexCreator (just have it create a point at 0,0) and then a TextAdder to add whatever you want to put in that label and then optionally a PDFStyler if you want to style it nicely.
Forum|alt.badge.img+50
  • August 4, 2022
ako_tde
  • August 5, 2022
@Hans van der Maarel​ :
Thanks for your support.
Your remarks & explanations helped me to accomplish my desired output – I understood the missing part and learned something new.
Thank you & much appreciation for your time :)
Kind Regards
Alexander
