Add single vertexes on lines at a certain distance from points
  • May 28, 2024 11:46 AM UTC
  • 147 views
repas4411
I’m wondering if there is a way to add vertexes (point) to polylines at a certain distance.
Lets say I have a .shp layer with several polylines. I also have a table with “errors” that have occurred somewhere on these polylines. The table have the following attributes:
Column 1: Line name (containing the names of the polylines in my .shp layer)
Column 2: Distance measured from XXXX (containing names of stations that connect to the polylines, this is where the distance is measured from)
Column 3: Distance (km)
So basically i know the exact point from where the distance is measured from, I know which polyline the error has effected, and I know the distance. Can I automatically map this out?
nielsgerrits
Forum|alt.badge.img+67
I think this can be done using measures.
Not tested but something like:
  • Split the lines on stations. (PointOnLineOverlayer?)
  • Merge the names of the stations to the lines. (CoordinateExtractor on stations and on point 0 of the line, merge on x,y)
  • Generate measures on the lines. (MeasureGenerator)
  • Merge the lines with measures on the errors. (FeatureMerger)
  • Generate points from measure mentioned in error. (Snipper)
Attached sample demonstrating this.
repas4411
  • May 29, 2024 7:09 AM UTC
What parameters should I put in the snipper? I tried the vast majority of the available attributes but get kind of wierd results
nielsgerrits
Have you checked the sample workspace?
