A problem with Statistics Calculator
  • Aug 11, 2020 11:00 AM UTC
  • 7 replies
  • 215 views
jan
The statistics Calculator gives this error when trying to count the sum of an attribute: 2020-08-11 12:49:59|2233.8| 2.3|ERROR |Python Exception <MemoryError>:
2020-08-11 12:49:59|2233.8| 0.0|FATAL |@Python failed to execute function `StatisticsCalculator.recordFeature'
2020-08-11 12:49:59|2233.8| 0.0|ERROR |StatisticsCalculator_2_InputProcessor (TeeFactory): StatisticsCalculator_2_InputProcessor: @Python execution failed
2020-08-11 12:49:59|2233.9| 0.1|ERROR |StatisticsCalculator_2_InputProcessor: @Python execution failed
There was approx 2.5M features passing through each one having a value of 1. So the sum operation should not be exhaustive. What could cause this? A bug?
Best answer by jan
I removed the "fme_feature_type_name" attribute and it seems to have solved the problem.
jan
  • Aug 11, 2020 11:01 AM UTC
Using fme 2019.2
srg
Forum|alt.badge.img+10
  • Aug 11, 2020 11:45 AM UTC
@jan​ Can you try running the process with only the attribute for which you need the statistics?
In other words use AttributeRemover to remove attributes of not interest for statistics calculation before sending the FME features to StatisticsCalculator.
jan
  • Aug 11, 2020 12:01 PM UTC
I can't remove but one attribute. I need all the others.
jan
  • Aug 11, 2020 12:37 PM UTC
jan
Should this be reported as a bug!?
DanAtSafe
Forum|alt.badge.img+23
  • Aug 11, 2020 4:47 PM UTC
Hi @jan​  Please try the latest FME 2020.2 beta and if the problem still exists then please submit a case. Thanks!
jan
  • Aug 12, 2020 6:23 AM UTC
I think Safe should test it. My Client uses FME 2019.2 and it is a hard job changing version since also FME Server is used with the same version.
