3D DWG surface to 2D polygon
  • Sep 9, 2020 5:24 AM UTC
  • 409 views
lcw
Hi all,
I have a 3D mesh in a DWG file (3D surface of a pavement) and want to convert its footprint to a single polygon in an Esri file gdb polygon feature class (for use in 2D GIS). Can ignore all attribute information. Tried following this post but without luck (I think I need more detailed instructions re settings for each transformer). Anyone here able to help me? Thank you!
https://community.safe.com/s/question/0D54Q000080hgjISAQ/turning-a-mesh-into-a-polygon
2020-09-09_15-01-28
deanhowell
Forum|alt.badge.img+24
  • Sep 9, 2020 7:12 AM UTC
Hello @lcw​ you might want to look into using the 2DForcer transformer followed by something like the HullReplacer
lcw
  • Sep 9, 2020 7:33 AM UTC
Hello, thanks for your reply! I actually found this discussion - it worked a treat! https://community.safe.com/s/question/0D54Q000080hdosSAA/surfacefootprintreplacer-and-polygons-with-holes
