With the latest upgrade to the AttributeExposer I'm no longer able to retrieve the fme_basename, which I need for further processing. Does anyone have a work-around for this?
michaelqatcord
Participant
@Michael257
daveatsafe
Forum|alt.badge.img+19
  • June 16, 2020
The format attributes fme_basename and fme_dataset are unique, in that they are not created unless they are exposed on the input feature types. You can expose them by right-clicking on the input feature type and choosing Properties from the menu, then choosing the Format Attributes tab.
michaelqatcord
Participant
Thanks Dave but my input feature types are arriving from a FeatureReader fed by a Schema reader of a cad file. Your solution doesn't seem to work. I should add that the problem only occurs on one of the 10 or so feature types (each one a cad layer) leaving the FeatureReader. It's bizarre as it works fine with version 0 and fails with version 1.
daveatsafe
  • June 16, 2020
In the reader Parameters in the FeatureReader, please click the triangle beside Schema Attributes, then the ... button beside Additional Attributes to Expose. This will bring up a dialog from which you can select fme_basename to expose.
You could also use the FileNamePartExtractor on the attribute containing the filename on the feature being input to the FeatureReader, but try exposing fme_basename first.
michaelqatcord
Participant
Thanks Dave - I had actually added the fme_basename and fme_dataset to the additional attributes to expose dialogue in the FeatureReader parameters before you mentioned it. This was to no avail. The fme_basename is gone but not forgotten after the FeatureReader. I'm not sure why the upgrade to the AttributeExposer has caused this problem. However, I've come upon a solution that is working. By adding a variablesetter before the FeatureReader, I'm able to retrieve the fme_basename later in the process and successfully continue processing to the end.
daveatsafe
  • June 17, 2020
In that case, I think you want to disable the fme_basename in the FeatureReader, since it will overwrite the one you want to keep from the CAD file. In the FeatureReader, please check that Attribute and Geometry Handling - Accumulation Mode is set to Merge Initiator and Result, to keep the attribute from the CAD file.
michaelqatcord
Participant
Hi Dave - as I used a different name ('filename') than fme_basename in the variable setter it's not overwriting the fme_basename and persists through the downstream side of the FeatureReader. Do you think I should still set the accumulation mode to Merge Initiator and Result? I'll give it a try yet just to see what happens, but everything is working fine now.
