Reshape polygon vertices to get uniform vertex distribution
chau
Forum|alt.badge.img+3
I have a polygon with lots of vertices. I want to create a new polygon with a uniform distribution (distance) of vertices along the edges. At the same time I would like to simply the polygon, thus removing vertices with a high density with no significant influence on the polygon shape.
I would like my result to be a polygon with vertices evenly distributed/spaced along the edges and only a more dense distribution where the shape of the polygon requires.
How can I do this in FME?
  • May 16, 2013
you could look at the Generalizer transformer, there are several algorithms to choose from, depending on your data and your needs.
There is also the Densifier that will add vertices at fixed intervals.
David
sigtill
Forum|alt.badge.img+24
  • May 16, 2013
Also the SherbendGeneralizer might be helpful.
  • May 16, 2013
agree about the SherbendGeneralizer, but it only works with polylines, so you would have to convert your polygons first (GeometryCoercer).
David
