Can I apply string functions to regex replacement text in a StringReplacer transformer?
tfcw
Participant
  • Participant
In my workbench I have a column full of strings where I'd like certain sequences of characters to be capitalized. I could do this by adding a StringReplacer for each sequence, but I have a lot of sequences and I'd rather not do that if I can solve the problem with a general solution. What I'd like to do is just use some StringReplacer like
Attributes: RAILWAY_NAME
Text to Find: Cpr|Cnr
Replacement Text: @UpperCase(\\0)
Use Regular Expressions: Yes
Case Sensitive: Yes
Where whatever it finds would be replaced with the upper case version. But when I try this on the string "Cnr Railway" nothing gets replaced. If I try it with the replacement text \\0+1 I get "Cnr+1 Railway", so I know the regex is matching correctly. If I try it with the replacement text @StringLength(\\0) I get "2 Railway", so it looks like functions take "\\0" as a literal string. But if that were the case why does @UpperCase(\\0) return "Cnr Railway"?
So my quesiton is:
1. Can I use FME String Functions on regex replacement text in a StringReplacer.
2. If yes, how. If no, is there an easy way to capitalize certain sequences of characters in a string.
I'm using FME Desktop 2013, if it matters.
Best answer by takashi
Hi @yola, can the StringPairReplacer help you?
  • Replacement Pairs: Cpr CPR Cnr CNR
Forum|alt.badge.img+31
  • March 31, 2016
Not sure whether this would work in 2013 or not, but this works in 2015
StringSearcher - Regular Expression as above
AttributeCreator - create a new attribute with the matched characters turned to uppercase
Stringreplacer - use the matched characters as text to match with the new attribute created above as replacement text
erik_jan
Forum|alt.badge.img+17
  • March 31, 2016
Would it not be easier to use two StringReplacers in sequence in this case?
And no regular expressions, just replace Cnr with CNR and Cpr with CPR.
  • March 31, 2016
I presume in reality the regular expression will be matching far more than 2 distinct letter sequences.
tfcw
Participant
  • Participant
  • March 31, 2016
Yup, I've got more than 2 sequences, and possibly more in the future. So I'd rather not add another transformer anytime a new one pops up
tfcw
Participant
  • Participant
  • March 31, 2016
This helps a lot but it's not quite what I need. Each string I take in possibly has more than one sequence within it, and this only replaces the first sequence it finds in a string.
But this does help a lot and I think with some tinkering it'll probably work, thanks.
Forum|alt.badge.img+19
  • March 31, 2016
tfcw
Participant
  • Participant
  • April 1, 2016
Yep, perfect. Thanks!
  • April 2, 2016
Good to hear :-)
It seems that a string function within the "Replacement Text" field is evaluated before the regex replacement. That is, "@UpperCase(\\0)" will be translated to "\\0" before replacing. Result, the input string will not be changed anyway. I think this is the reason why you cannot get your expected result from the function use.
