Assistance needed with comparing location across two Datasets :
  • Mar 19, 2025 12:27 AM UTC
  • 148 views
tauseef144
Dear All,
I’m  working with two datasets that share a common key: Station ID. Each dataset provides coordinates ( latitude and longitude) for these stations. My objective is to determine whether the station with the same ID have identical location in both datasets or if there are discrepancies.
To achieve this, I need to calculate distance between the corresponding coordinates from both datasets. While this seems straightforward, but I encountering challenges in implementing it effectively. I would appreciate any help on the best approach.
Thank you in advance.
BR//
Best answer by geomancer
Use a NeighborFinder, group by Station ID.
crutledge
Forum|alt.badge.img+55
  • Mar 19, 2025 3:52 AM UTC
Hi ​@tauseef144
I wonder if you could use a FeatureJoiner and Join on SationID then in the AttributeManager to add two attributes LonCalc and LatCalc, do a quick calculation using the two Lon and two Lat? So Lon1-Lon2 and Lat1-Lat2 to see if there’s a difference. Would that work?
geomancer
Forum|alt.badge.img+71
  • Mar 19, 2025 8:38 AM UTC
tauseef144
  • Mar 19, 2025 7:42 PM UTC
Thank you ​@crutledge & ​@geomancer. I found using NeighborFinder is easy, it work just fine. only thing I noticed that if Station IDs are duplicate then it doesn’t show value for these duplicates.
