@Value no Work
  • Mar 22, 2025 6:02 PM UTC
  • 81 views
mr_fme
Forum|alt.badge.img+9
I need using attribute value to create another attribute, but the @Value<attributeName> no work in attribute creator.
Can you help me?
Thank´s
Best answer by nielsgerrits
It probably does, but the created attribute will be unexposed.
nielsgerrits
Forum|alt.badge.img+67
crutledge
Forum|alt.badge.img+55
  • Mar 22, 2025 11:23 PM UTC
Hi ​@mr_fme I don’t understand why you would need @Value(MES) in this situation. If I understand correctly you want to create an attribute MES and populate it with the value from MEDIA. Have you tried just MES for Output Attribute and MEDIA for Value?
