@Value no Work
mr_fme
Forum|alt.badge.img+9
I need using attribute value to create another attribute, but the @Value<attributeName> no work in attribute creator.
Can you help me?
Thank´s
Best answer by nielsgerrits
It probably does, but the created attribute will be unexposed.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
nielsgerrits
Forum|alt.badge.img+54
  • March 22, 2025
crutledge
Forum|alt.badge.img+33
  • March 22, 2025
Hi ​@mr_fme I don’t understand why you would need @Value(MES) in this situation. If I understand correctly you want to create an attribute MES and populate it with the value from MEDIA. Have you tried just MES for Output Attribute and MEDIA for Value?
