AutoCAD Join between insert point block and geometry
arxit
Forum|alt.badge.img+5
Hello
I need to make a join between a geometry (polygon) from a block (DWG File), and the insertion point of this geometry :
How can I do this ?
Is there a unique common Identifiant betwen insertion point and geometry, for a block object ?
I need to do this because I have to put the autocad_entity_handle of the insert point in the geometry (polygon) attribute (because autocad_entity_handle is not a unique ID for the polygon from the block).
I used the "Preserve Insert Point" in DWG Reader Options :
Thank you.
daveatsafe
Forum|alt.badge.img+19
  • December 5, 2018
Hi @arxit,
The format attribute autocad_block_number can be used to link the exploded block components to the insertion point. This value is unique for each block insertion.
arxit
  • December 6, 2018
Perfect, it works !
Thank you very much Dave.
