Hello-
I have used the following example to some success, but I have some questions regrading the rounding of the block and when the incident location is an intersection. In this case I need to just pass on the street name to the location and not have it pass through the attribute manager that adjusts the address number. I am also using a geocoder published to ArcGIS server instead of a CAD file.
Thanks!!
