Hi, I get an error message because of a permission. Had anyone a similar error?
  • Jul 6, 2023 1:30 PM UTC
  • 171 views
Error executing SQL command ('TRUNCATE TABLE "quali"."wa_hydrant"'): 'ERROR: permission denied for table wa_hydrant
Error truncating table 'quali.wa_hydrant'. Assuming table exists and attempting to append
Error executing SQL command ('COPY "quali"."wa_hydrant" ("gis_id", "gesellschaft_bd", "gemeinde", "standortwerk", "_rbe", "_fehler_nr", "_fehler", "_pruefdatum", "_fme_prozess", "_temptext1", "_temptext2", "_temptext3", "_temptext4", "_temptext5", "_temptext6", "_temp_num1", "_temp_num2", "_temp_num3", "_temp_num4", "_temp_num5", "_temp_num6", "fstatus_id", "geom_pt") FROM STDIN USING DELIMITERS ':' WITH NULL AS 'NULL''): 'ERROR: current transaction is aborted, commands ignored until end of transaction block
POSTGIS writer: A fatal error has occurred. Check the logfile above for details
NullAttributeMapper_OUTPUT_-1_337_Player (RecorderFactory): POSTGIS writer: A fatal error has occurred. Check the logfile above for details
Successfully closed POSTGIS database writer
evieatsafe
Forum|alt.badge.img+28
  • Jul 6, 2023 9:36 PM UTC
Hi @sknaps​ thanks for your question! What version and build number of FME are you using? Are you able to write to the table without truncating as a test? (i.e. use existing?)
This does look like a permissions issue, any additional information you could provide would be helpful!
  • Jul 7, 2023 8:15 AM UTC
Hi @ EvieAtSafe
I use "FME Workbench 2021.1.1" I succesfully tested writing and truncating the table with pGAdmin.
In FMEwriting works, just truncating creates an error.
  • Jul 7, 2023 10:50 AM UTC
Problem is solved. It was an internal database permission problem.
Thanks
