Hi all, how do I easiest update change the field type in a GDB?
Esri Introduced the BigInteger, which is giving me a lot of issues. It dosn’t work in all applications, and I can’t even do a relate or join on it.
I need to get it into a integer. For some reason the data we get delivered now on a weekly basis has all the number fields in BigInteger.
I need it to find the BigInteger Fields, and change the type, without loosing data. The data also fits an normal integer.
Any thoughts would be much appreciated.
Thanks
Best answer by debbiatsafe
