Hi @mohamdwassouf thank you for your question. Could you provide some sample data and perhaps we could assist you in your efforts.
From your photos, assuming that the left inputs are CityGML and the right outputs are Shapefile, it should run. However, you may need to check your attributes as they will be named differently in the Shapefile.
If you could also describe the problem you have with the coordinates and dimensions of the building, we can try to help with that as well.
Cheers, Evie
Cheers, Evie
Thank you for your interest in helping me solve this problem
I'd like to convert this file from citygml to a shapefile with a location for the build on the map
Thank you @mohamdwassouf for sharing your file.
looking at your file, I see that it does transform the CityGML to shapefile perfectly fine (with a few missing attributes as mentioned previously); however, even though it does have a coordinate system it does not seem to be georeferenced.
If you know where this building is supposed to be located, you can add this information manually in FME perhaps by using a combination of the GeometryReplacer, the LocalCoordinateSystemSetter, and the Scaler. Check out this article for more ideas on how this might be possible.
Thank you very much for helping me with this problem
This is the .ifc file for the same building and it has a georeference but when converting it to citgml the location coordinates are lost
How can I keep it from being lost?
Hi @mohamdwassouf thanks for replying, where are you creating your IFC files? It seems that when the IFC files are loaded into FME it no longer has a spatial reference. I'm not sure if this is how you were transforming your IFC into CityGML, if you were using FME to do so this is likely the root of your issue.
Like I said previously, with the information of where this building is supposed to be located, you can add this information manually in FME perhaps by using a combination of the GeometryReplacer, the LocalCoordinateSystemSetter, and the Scaler.
If this is impacting your production and the article I provided does not help, I would suggest submitting a support case to have this resolved.
Cheers, Evie
