Is there a limit on the amount of memory/RAM FME 2016 32Bit can utilise on a machine?
  • Oct 20, 2016 4:12 PM UTC
  • 72 views
Hi All,
I'm currently running several memory hungry models using FME 2016 32Bit (as I'm using ESRI software therefore 64bit is unsuitable), but I keep getting the 'Translation Failed' due to memory issues. Just to clarify, I only run one at a time and have had to break them down in order for them to complete. I've attached an image of the memory available on my machine and am unable to find a reason as to why it's failing. I've been monitoring the memory usage throughout and at most the models are utilising 10-20% of the available memory. Is there a cap on what FME can utilise?
Any recommendations greatly appreciated.
rylanatsafe
Forum|alt.badge.img+14
Please refer to this question posted by another member of the FME Community: https://knowledge.safe.com/questions/2319/fme-32-bit-vs-64-bit.html
32-bit FME will only be able to access ~4GB of memory on a 64-bit OS. This is a limitation of 32-bit applications.
You might need to split the workspaces into different components, or reduce feature input, so that FME doesn't hit this cap during translation.
  • Oct 21, 2016 7:37 AM UTC
I'll add that if you're running reasonably recent versions of FME and ArcGIS, there's a decent chance that you could make it work with the 64-bit versions.
For more details: https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
  • Oct 21, 2016 8:09 AM UTC
Thanks everyone. I'm writing out to ArcSDE therefore only using the 32bit version. I may try the 64 bit but write out to a fileGDB instead and then move the final data across.
