Is FME Server compatible with ArcGIS Desktop and ArcGIS Engine?
fmelizard
Forum|alt.badge.img+20
Best answer by jlutherthomas
    If a user wishes to use FME Server with ESRI products/functionality, please be aware of the following:
    • If the end user is using FME Server with ArcGIS, they must use ArcGIS Enterprise (formerly “ArcGIS Server”)
    • ArcGIS Desktop and ArcGIS Engine are not for use in “server environments”
    • Having ArcGIS Desktop on the same machine as FME server so that FME Server can exploit some functionality (eg GP, python scripts, etc) is not permitted in the Esri license
    • November 10, 2017
      • November 10, 2017
        When explaining the second point regarding "server environments" to clients, it would be great to have something official from ESRI to refer to, if you have a URL or other document?
        brianatsafe
        Forum|alt.badge.img+13
        • November 10, 2017
        hi @david_r, here is Esri's standard terms: http://www.esri.com/legal/software-license. I hope that is helpful. We cannot speak to legalities or provide legal advice on these terms.
