HTTPCaller Transformer using the Post method returns a uninteded result
liujisheng
Participant
I used the httpcaller transformer call the Baidu NLP api using the post method. But I have got a uninteded result.
Baidu NLP API: http://ai.baidu.com/docs#/NLP-API/top
Now I use the lexer for example.
Http method: POST
Request url: https://aip.baidubce.com/rpc/2.0/nlp/v1/lexer
Url parameter??Valid for one month?access_token=24.04f6c0626853e9c8b18ffbbaf5a0743b.2592000.1532943274.282335-11467307
Header : Content-Type=application/json
Body:?json,requires gbk encoding?
"text":"??????????"
If called successfully , it will return a json(encoding in gbk?,just like below.
{ "text":"??????????", "items":[ { "byte_length":4, "byte_offset":0, "formal":"", "item":"??", "ne":"ORG", "pos":"", "uri":"", "loc_details":[ ], "basic_words":["??"] }, { "byte_length":2, "byte_offset":4, "formal":"", "item":"?", "ne":"", "pos":"v", "uri":"", "loc_details":[ ], "basic_words":["?"] }, { "byte_length":4, "byte_offset":6, "formal":"", "item":"??", "ne":"", "pos":"m", "uri":"", "loc_details":[ ], "basic_words":["?","?"] }, { "byte_length":6, "byte_offset":10, "formal":"", "item":"???", "ne":"", "pos":"n", "uri":"", "loc_details":[ ], "basic_words":["?","??"] }, { "byte_length":4, "byte_offset":16, "formal":"", "item":"??", "ne":"", "pos":"n", "uri":"", "loc_details":[ ], "basic_words":["??"] } ] }
Httpcaller parameter:
The return I have got:(It returned a html file instead of a json file.)
I also tried this method on postman. It works pretty well.
I have troubled in this problem for two days. And searched every similar answer in the knowledge center. But I still don't know where the problem is.
Any help is appreciated.
JISHENG LIU
Best answer by takashi
Hi @liujisheng, I was able to get desired response (JSON) with this setting.
Upload Body (Value of "_result"):
{ "text" : "???????" }
HTTPCaller Parameters:
Response Body:
   "log_id" : 6729234485593642004,
   "text" : "???????",
   "items" : [
         "loc_details" : [],
         "byte_offset" : 0,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "??",
         "basic_words" : "??" ],
         "byte_length" : 6,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 6,
         "uri" : "",
         "pos" : "v",
         "ne" : "",
         "item" : "?",
         "basic_words" : "?" ],
         "byte_length" : 3,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 9,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "???",
         "basic_words" : "?""??" ],
         "byte_length" : 9,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 18,
         "uri" : "",
         "pos" : "w",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
  • July 1, 2018
Response Body:
   "text" : "???????",
   "items" : [
         "loc_details" : [],
         "byte_offset" : 0,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "??",
         "byte_length" : 6,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 6,
         "uri" : "",
         "pos" : "v",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 9,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "???",
         "byte_length" : 9,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 18,
         "uri" : "",
         "pos" : "w",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
liujisheng
Participant
  • Participant
  • July 1, 2018
Response Body:
   "text" : "???????",
   "items" : [
         "loc_details" : [],
         "byte_offset" : 0,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "??",
         "byte_length" : 6,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 6,
         "uri" : "",
         "pos" : "v",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 9,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "???",
         "byte_length" : 9,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 18,
         "uri" : "",
         "pos" : "w",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
Thanks a lot. I have got my desired response (JSON) by follow your suggestion.
  • July 1, 2018
Response Body:
   "text" : "???????",
   "items" : [
         "loc_details" : [],
         "byte_offset" : 0,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "??",
         "byte_length" : 6,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 6,
         "uri" : "",
         "pos" : "v",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 9,
         "uri" : "",
         "pos" : "",
         "ne" : "LOC",
         "item" : "???",
         "byte_length" : 9,
         "formal" : ""
         "loc_details" : [],
         "byte_offset" : 18,
         "uri" : "",
         "pos" : "w",
         "ne" : "",
         "item" : "?",
         "byte_length" : 3,
         "formal" : ""
?????????HTML???????????????API?????Header????????Headers???Content-Type: application/json????????????
liujisheng
Participant
  • Participant
  • July 1, 2018
???????api?????????????????????????????????? ··· ···
