HTTP Caller unexpected 400 (bad request)
  • Jun 6, 2023 11:45 AM UTC
  • 137 views
albinepro
Forum|alt.badge.img+7
I'm using HTTP Caller for geocoding adresses, but somehow I'm getting randomly lot of 400 responses - e.g. 2 of 12 calls are succesfull. If I copy paste the URL from error log to browser I'll get the result correctly.
I'll share the worspace template temporarily including the API key of Geoapify. I don't know why I'm getting 400 (bad request).
Best answer by david_r
You need to manually URL-encode the values when concatenating them with the base URL, especially when using extended characters (accents, etc):
imageAlternatively, the HTTPCaller can do it for you automatically if you use the query string setting rather than manually concatenating the base URL:
  • Jun 6, 2023 12:59 PM UTC
albinepro
  • Jun 6, 2023 1:49 PM UTC
Great, exploding the parameters from URL request to Query String Parameters did the job and is probably more clear for later inspection. Thanks
