How to update the metadata of an item in ArcGIS Online?
friesewoudloper
I would like to update metadata of an item in ArcGIS Online using FME Desktop.
With the help of Thomas Maschler I succeeded in updating the AOL metadata using a Python script: https://gist.github.com/FrieseWoudloper/590d428afce5d2d873bd6b4b81acc1d9
I try to do the same in FME Deskop using HTTPCaller, but this isn't working properly. The workspace runs succesfully and returns HTTP status code 200 (OK), but the metadata is unchanged.
See attached my workspace. I also have an XML-file for testing purposes.
Any help would be appreciated.
Willy
friesewoudloper
I think that this is my problem:
What is the equivalent of this line of Python code in HTTPCaller?
f = {'metadata': ('metadata.xml'open(metadata, 'rb'), 'text/xml', {'Expires''0'})}
friesewoudloper
The solution turned out to be quite easy :-)
Still I am interested to know if there is a better way to update the metadata.
ronk
  • October 11, 2018
I am also trying to upload metadata to argcis online for a very long time now.
Could you please elaborate your solution?
I used the example workspace from friesewoudloper but I keep getting the http status code 200.
What do I put as "item"? Is it simply the name of my arcgis online object?
Best Regards, Ron.
friesewoudloper
ronk wrote:
Best Regards, Ron.
Item is the global unique identifier of the item.
Let's say you want to update metadata of a hosted feature service. Look at the URL of the page of the hosted feature service.
For example http://provgroningen.maps.arcgis.com/home/item.html?id=91d9c4ef1f564ee4ac7f8358c54514b6
Item is 91d9c4ef1f564ee4ac7f8358c54514b6
Maybe I should have named the parameter item_id.
friesewoudloper
ronk wrote:
Best Regards, Ron.
agol-metadata-new.fmw
Apparently ESRI made some changes to their API. See attached the updated workspace. You have to change the values of all private parameters.
ronk
  • November 30, 2018
ronk wrote:
Best Regards, Ron.
Thanks! It works! :-)
jan_van_prooije
Hello Friesewoudlooper,
Is it possible to share the workspace with again? When i try to download it now it is not available anymore.
Thanks,
Jan
friesewoudloper
Thanks,
Jan
https://github.com/FrieseWoudloper/fme/tree/master/agol-metadata
  • January 6, 2020
Thanks for the link!
dannymeus
Forum|alt.badge.img+4
  • May 28, 2020
@friesewoudloper is the workspace (arcgis-rest-api-experiment.fmw) still available? I can't download it via the link....
