How to read from a historic moment for an archived dataset using the Esri ArcGIS Portal Feature Service reader?
  • April 11, 2023
  • 53 views
rchoucroun
Forum|alt.badge.img+19
I have a requirement to read from a service that is published to ArcGIS Portal but I need to read from a historic moment based on the last run time of my workspace. If I were able to access the database directly, I could query the archive tables. However, I need a solution that will read the service.
There is an idea which requests this functionality, but so far, this doesn't appear to have been implemented. Is there a workaround for this?
I'm using 2022.2.2
hkingsbury
Forum|alt.badge.img+61
  • April 11, 2023
(not an expert on archiving) Could you make the call through the REST api (using an HTTP Caller) and recreate the feature from the response body?
