fme flow 2023.02 does not run jobs with a link to gdb or sde
  • Aug 5, 2023 8:52 PM UTC
  • 0 replies
  • 76 views
dor1411993
Hi
After our server was upgraded to fme flow, the jobs that run together with ESRI services (gdb, sde) do not run, and this error is given:
Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility workspace parameter, found in Navigator -> Workspace Parameters -> Translation. This 64-bit version of FME requires ArcGIS Desktop along with 64-bit Background Geoprocessing; ArcGIS Pro; or ArcGIS Enterprise. Refer to this this article http://fme.ly/qua for more details
Of course, in the previous version of the server, everything worked smoothly,
And also when I run the same jobs on the server's machine, along with fme form, everything works fine.
There is ArcGIS Pro with a license, and full access for all users.
I would appreciate your urgent help!
Thank you!
