FME Equivalent to Merge in ArcGIS
I have four different feature types that I want to merge into a single feature class. In ArcGIS, the merge tool will keep all unique attribute fields, which is what I want. I have looked into FeatureMerger, but I don't think that will work, since I am not trying to join anything. Are there any transformers that can perform this operation?
I am using FME 2016.
Best answer by mark2catsafe
If I understand correctly, you just need to connect everything to the same transformer/feature type. If you set the attribute mode to automatic on the writer then you will get all of the attributes written out.
Quick demo movie here: http://screencast.com/t/wIaEXui3
  • June 24, 2016
Basically I'm trying to find something like Aggregator, but to preserve individual features. Is there is a way to do this with Aggregator?
Forum|alt.badge.img+5
  • June 24, 2016
  • June 24, 2016
Thanks, that's exactly what I need to do.
