Esri ArcGIS Server Feature Service
losanca
Forum|alt.badge.img+4
A month ago, I generated an fmw (Build 24202) that read from Esri ArcGIS Server Feature Service, (url, user, pwd) correctly.
today when opening the fmw gives error and is not able to read, I do not know why it can be, if everything is the same as a month ago.
Thank you so much!
hkingsbury
Forum|alt.badge.img+61
  • September 2, 2024
Are you using a web connection to provide authentication with the credentials? You may need to just re-authenticate the connection
losanca
  • September 7, 2024
thanks hkingsbury
I can’t connect because of insufficient permissions
hkingsbury
  • September 9, 2024
losanca wrote:
thanks hkingsbury
So you are using a web connection? Has the error being returned is one from arcgis so that suggests the username/password combination is not correct
