Data shifting FME/ArcGIS
When I bring lat/long data stored in SDE (NAD 83) into FME and run it through all of my transformers associated with doing an AreaOnAreaOverlayer the output appears to shift when I compare it to the original data in ArcMap. Here's a zoomed in area. The light purple color is the FME output. Any ideas why it would not maintain the exact integrity of the input data?
Best answer by david_r
it's difficult to tell without seeing the workspace. Are you perhaps doing some implicit snapping somewhere? Clipping against two almost similar datasets? Rounding of coordinates?
David
  • May 23, 2014
David
David I had figured it out at the end of yesterday. But you get the best answer because you hit on something I was doing that was causing the issue. I was rounding the coordinates. When I took that transformer out everything overlayed perfectly. Thanks for answering!!!
