Coordinate system for Italy, RDN 2008
  • Mar 25, 2024 9:22 AM UTC
  • 458 views
pdorio
Forum|alt.badge.img+8
While waiting for the Italian coordinate systems to be included in the base library, I would like to share the customised coordinate system to define the following reference systems:
  • Datum “Rete Dinaminca Nazionale 2008”
  • RDN2008 (LL) EPSG:6706
  • RDN2008 / Italy zone (N-E) EPSG:6875
  • RDN2008 / Italy zone (E-N) EPSG:7794
  • RDN2008 / UTM Zone 32N EPSG:7791
  • RDN2008 / UTM Zone 33N EPSG:7792
  • RDN2008 / UTM Zone 34N EPSG:7793
Here is the definition to be copied into the file
C:\Program Files\FME\Reproject\MyCoordSysDefs.fme
#### RDN2008 ####
DATUM_DEF RDN2008                                             \
   DESC_NM    "Rete Dinamica Nazionale 2008 (ETRF 2000)"  \
   SOURCE     "PROJ4"                                         \
   ELLIPSOID  GRS1980 \
   USE 7PARAMETER
   DELTA_X 0                           \
   DELTA_Y 0                             \
   DELTA_Z 0                             \
   BWSCALE 0                          \
   ROT_X 0                          \
   ROT_Y 0                            \
   ROT_Z 0
COORDINATE_SYSTEM_DEF "RDN2008"    \
    CS_NAME    RDN2008 \
    DESC_NM "RDN2008 EPSG:6706"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 6706 \
    GROUP ITALY \
    PROJ LL    \
    MAX_LAT 47.10                           \
    MAX_LNG 18.99                           \
    MIN_LAT 34.76                           \
    MIN_LNG 5.93                            \
    ORG_LNG 0.0174532925199433 \
    QUAD 1    \
    MAP_SCL 1    \
    UNIT DEGREE
COORDINATE_SYSTEM_DEF "RDN2008 / Italy zone (N-E)"    \
    CS_NAME    RDN2008_NE \
    DESC_NM "RDN2008 / Italy zone (N-E) EPSG:6875"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 6875 \
    GROUP ITALY \
    PARM1 12    \
    PROJ TM    \
    MAX_LAT 47.10                           \
    MAX_LNG 18.99                           \
    MIN_LAT 34.76                           \
    MIN_LNG 5.93                            \
    QUAD 1    \
    SCL_RED 0.9985000000    \
    UNIT METER    \
    X_OFF 7000000
COORDINATE_SYSTEM_DEF "RDN2008 / UTM Zone 32N"    \
    CS_NAME    RDN2008_UTM32N \
    DESC_NM "RDN2008 / UTM Zone 32N EPSG:7791"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 7791 \
    PARM1 9    \
    PROJ TM    \
    MAX_LAT 47.04                           \
    MAX_LNG 12.00                           \
    MIN_LAT 36.53                           \
    MIN_LNG 5.93                            \
    QUAD 1    \
    SCL_RED 0.9996    \
    UNIT METER    \
    X_OFF 500000
COORDINATE_SYSTEM_DEF "RDN2008 / UTM Zone 33N"    \
    CS_NAME    RDN2008_UTM33N \
    DESC_NM "RDN2008 / UTM Zone 33N EPSG:7792"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 7792 \
    PARM1 15    \
    PROJ TM    \
    MAX_LAT 47.10                           \
    MAX_LNG 18.00                           \
    MIN_LAT 34.79                           \
    MIN_LNG 12.00                            \
    QUAD 1    \
    SCL_RED 0.9996    \
    UNIT METER    \
    X_OFF 500000
COORDINATE_SYSTEM_DEF "RDN2008 / UTM Zone 34N"    \
    CS_NAME    RDN2008_UTM34N \
    DESC_NM "RDN2008 / UTM Zone 34N EPSG:7793"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 7792 \
    PARM1 21    \
    PROJ TM    \
    MAX_LAT 41.64                           \
    MAX_LNG 18.99                           \
    MIN_LAT 34.76                           \
    MIN_LNG 17.99                            \
    QUAD 1    \
    SCL_RED 0.9996    \
    UNIT METER    \
    X_OFF 500000
COORDINATE_SYSTEM_DEF "RDN2008 / Italy zone (E-N)"    \
    CS_NAME    RDN2008_EN \
    DESC_NM "RDN2008 / Italy zone (E-N) EPSG:7794"      \
    EL_NAME GRS1980    \
    DT_NAME RDN2008 \
    GROUP ITALY \
    EPSG 7794 \
    PARM1 12    \
    PROJ TM    \
    MAX_LAT 47.10                           \
    MAX_LNG 18.99                           \
    MIN_LAT 34.76                           \
    MIN_LNG 5.93                            \
    QUAD 1    \
    UNIT METER    \
    X_OFF 7000000
geomax
Forum|alt.badge.img+3
  • Mar 26, 2024 10:43 AM UTC
Hello pdorio,
thanks for your post. I have the same problem, I have to add the coordinate system for EPSG 6875 in FME and I never did before.
I used your previous post on the same topic : Mistakes by configuring a new Custom Coordinate System [RDN2008 (ETRF2000) Italy zone (N-E) EPSG:6875] | Community (safe.com)
But I have seen that if I add the coordinate system and I perform a reprojection the result, compared with Qgis, is different. Looks like that In FME after a reprojection a shift is created. So, I assume that I did some error.
Please, can you explain me how to add the new code created by you to have a good result.
Thanks
Max
