Hi. I am trying to connect a Smartsheet sheet via the Smartsheet API to FME to be able to import the information for further processing. I attempted to use the HTTPCaller transformer for this. I have not been succesfull and seam to fail the authentication process even with using the correct token for the sheet. Is it possible to connect to Smartsheets in such a way? Is there any further advice that may help to achieve such a connection. I am using FME Desktop 2020. Examples would be great if this can be done.
