ArcGIS Portal Feature Service writer error True curve update not allowed
  • Oct 2, 2023 8:31 PM UTC
  • 428 views
jimmybowden29
FME Server 2022.2
Build 22765 - win64
I have an ArcGIS Portal Feature Service writer set up to update a single attribute. I am getting the following error ArcGIS Portal Feature Service Writer: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Unable to complete operation.'. Details: 'True curve update not allowed.'
I have specified to not update the spatial column so I would expect this error would not occur.
imageIt would appear that FME is trying to send a geometry image
davekazemi
Forum|alt.badge.img+5
  • Feb 14, 2024 1:10 AM UTC
it seems updating true curve is not supported and I’d suggest upvote here
deanhowell
Forum|alt.badge.img+24
  • Sep 25, 2025 3:41 AM UTC
​@jimmybowden29 did you find a work-around for the issue you mentioned above?
birgit
Forum|alt.badge.img+25
  • Sep 25, 2025 7:17 AM UTC
You can try to use the geometryremover transformer beforehand and set your writer geometry to arcgisonline_no_geom. It might also be possible that only the latter also works but just try out a combination of these two options.
Or you can change the settings on the ESRI service to allow updates from non curve clients.
