ReleasedFME 2024.1
HTTPCaller to specify client certificates
Related products:Transformers
marc_dragunski
+28
  • marc_dragunski
    marc_dragunski
  • lauryn00745
  • koenanthuenis
  • david_r
  • redgeographics
  • danilo_fme
    danilo_fme
  • lifalin2016
    lifalin2016
  • tcrossman
    tcrossman
  • fgiron
    fgiron
  • martinkoch
    martinkoch
  • smol
    smol
  • carstenotto
    carstenotto
  • fran-gd
    fran-gd
  • mattias
    mattias
  • dj_huisman
  • bartm
  • asatyawan
    asatyawan
  • lucit
  • mmccart
    mmccart
  • robotix
    robotix
  • marnickcle
    marnickcle
  • perry
    perry
  • tino
    tino
  • _fabian_
    _fabian_
  • phoeffler
    phoeffler
  • arjan_heil
    arjan_heil
  • judith
    judith
  • afoletti
  • d.staudt
  • kristofboschman
    kristofboschman
  • steveatsafe
    steveatsafe
  • rvanwijk
    rvanwijk
  • tkaufmann
    tkaufmann
martinkoch
Hello all,
Working for Dutch local governmental organisations, I more and more encounter webservices which require a certificate to be send as part of the authentication / authorization process. My guts feeling is, that this is especially the case with API's providing 'personal information', and that it is a hobby of Java developers...
Searching the Safe forums, I found this post most prominent, which suggests to use the python requests library (also the most FME compatible solution The Internet provides).
I can't see how to implement this in a connection-services-template...
So, please Safe Software, make this possible...
Martin
  • June 2, 2022
Very much needed! Please implement this feature.
phoeffler
Forum|alt.badge.img+5
  • August 12, 2022
This would also be useful for an ongoing project with our organization.
_fabian_
  • September 22, 2022
DTAG also requires this...
Edit: For anyone who also needs to use the DTAG Telekom MB2B REST API, here's my Python Code to get the contract list:
Startup-Python-Script
global cert
global key
cert = FME_MacroValues['FME_SHAREDRESOURCE_DATA'] + "certs/Telekom/cert.crt"
key = FME_MacroValues['FME_SHAREDRESOURCE_DATA'] + "certs/Telekom/private.key"
PythonCaller:
import fme
import fmeobjects
import requests
from requests.adapters import HTTPAdapter
from requests.packages.urllib3.util.retry import Retry
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        headers = {
            "Authorization""Bearer " + feature.getAttribute('token'),
            "Customer-Number": feature.getAttribute('RELATEDPARTY')
        url = \
        FME_MacroValues['URL'] + \
        "productInventoryManagement/" + \
        FME_MacroValues['VERSION'] + \
        "/product?agreement.id=" + \
        FME_MacroValues['FRAMECONTRACT'] + \
        "&relatedParty.id=" + \
        feature.getAttribute('RELATEDPARTY') + \
        "&productOrder.externalId=00000&filter.product.type=tariffList&limit=0"
        retry_strategy = Retry(
            total=3,
            status_forcelist=[400429500502503504],
            allowed_methods=["HEAD""GET""OPTIONS"]
        adapter = HTTPAdapter(max_retries=retry_strategy)
        http = requests.Session()
        http.mount("https://", adapter)
        http.mount("http://", adapter)
        response = http.get(url, headers=headers, cert=(cert, key))
        feature.setAttribute("contracts_list",response.text)
        self.pyoutput(feature)
    def close(self):
        pass
  • February 9, 2023
This is recurring request for us as well.
perry
  • June 21, 2023
Hope the issue is realized soon!
lifalin2016
Forum|alt.badge.img+37
  • August 18, 2023
I suggested the same thing back in 2020, but sofar nothing :-(
  • October 31, 2023
This is increasingly important, as more and more APIs are getting stricter access control. We are seeing a marked uptick in the number of private API endpoints that now require using a client certificate, which unfortunately can only be done using non-trivial Python code.
Suggestion: implementing an option in the HTTPCaller to specify a PKCS#12 (.p12) certificate archive and associated password would help a very long way. This would be the equivalent in cURL:
curl --cert-type P12 --cert <cert-file.p12>:<password> https://api.example/endpoint
@richardatsafe​ @steveatsafe​ Any chance of getting this into 2024?
steveatsafe
Forum|alt.badge.img+13
  • November 1, 2023
pushing for it... (but I won't pretend I have any weight on the decision to move on this).
It's getting harder to not support this.
LizAtSafe
Forum|alt.badge.img+16
  • September 26, 2024
OpenReleased
LizAtSafe
OpenReleased
LizAtSafe
OpenReleased
