Open
Add a 'Case sensitive' Option to the Joiner
Related products:Transformers
  • October 29, 2015
  • 8 replies
  • 145 views
lars_de_vries
Forum|alt.badge.img+10
Add a 'Case sensitive' option to the Joiner. Sometimes capitalization of attributes differs between source and target attributes. It would be nice if you could just use an option to take this into account or not.
geosander
Forum|alt.badge.img+7
Yes, this is a great idea. In fact, I think this should be an option for a lot of transformers where strings are being compared (e.g. Tester, TestFilter, AttributeValueMapper...). Sometimes, I don't care how FME compares values, but I do need to keep the original writing style. Now I need to copy the old value and apply an @LowerCase() function or StringCaseChanger, which clutters my workflow a little.
I had the same idea for the featuremerger,...
rylanatsafe
Forum|alt.badge.img+14
See also Idea: 'Case Sensitive' option when testing attribute values.
oscard
Forum|alt.badge.img+23
  • January 16, 2018
Having that option in the FeatureMerger (or any other transformer with similar functionality) would be a charm!
Yesterday, I had to deal with un unexpected change of case that nobody told me about.
jdh
Forum|alt.badge.img+41
  • December 10, 2018
The Tester now has Case Sensitive, Case Insensitive options in the Comparison mode. It would be nice if the FeatureMerger/Feature joiner could do so as well.
PierreAtSafe
Forum|alt.badge.img+11
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
philipv
  • April 17, 2026
Please also add for the ChangeDetector.
PierreAtSafe
Hi ​@philipv,
Drafting some potential improvements to the ChangeDetector right now, your comment is arriving at a perfect time! I’ll add this to the considerations.
If you have more requests for the ChangeDetector, don’t hesitate to indicate them in this Idea:
Cheers
